index of all zero values in 1D array
I would like to index all zero values in a 1D array. the problem is my points fluctuate around zero without reaching the zero value. So I need to do interpolation between the points.
I don't know how I can index all zero value. Can you please help me ?
regards,
Sylvain
Message 1 of 19
(6,628 Views)
Hi Sylvain,
it should be possible with the "Threshold 1D Array" function.
Mike
Message Edited by MikeS81 on 07-28-2009 05:30 PM
Message 2 of 19
(6,615 Views)
The problem is the VI "Threshold 1D Array" index only the first value egal to zero and doesn't index the other values in the 1D array.
Sylvain
Message 3 of 19
(6,607 Views)
I would use 'In Range and Coerce'.
In my example (attached), all values between -0.1 < x < 0.1 will be considered zero.
It then outputs a 2D array of (Index, Value)
Cory K
Message 4 of 19
(6,600 Views)
I would try a variation of this. You can replace the Not Equal To Zero function in that example with the In Range and Coerce.
Message 5 of 19
(6,593 Views)
Also be careful if you are working with floating point numbers. 1E-22 (as an example) is not equal to zero but it is indeed a small number 😉
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 6 of 19
(6,594 Views)
If you don't need to interpolate the index you can check for changes in the sign. See example.
Hope this helps,
Daniel
Message 7 of 19
(6,592 Views)
Indexes.JPGTo build on what smercurio_fc said here is a solution with comments.
Message Edited by VADave on 07-28-2009 11:52 AM
Visualize the Solution
CLA
LabVIEW, LabVIEW FPGA
Message 8 of 19
(6,567 Views)
It precisly my problem, because I'm working with floating poin numbers... I think, i need to use "Threshold 1D Array". What do you think ?
Message 9 of 19
(6,550 Views)
Could you please show us some sample data, and tell us what you would consider a zero?
Cory K
Message 10 of 19
(6,540 Views)
