initialize control values ​​during execution with the state machine
how I can program my state machine to initialize controls in my program when the program is running because it only takes the value it had before I ran my program
thanks in advance
Message 1 of 8
(2,840 Views)
Accepted by ameletudiante99
Hi Amelie,
Create an "init controls" state and do whatever you need to do in this state…
Do you use a (typedefined) cluster in a shift register to hold statemachine-internal data: you better initialize this cluster instead of some controls on your frontpanel…
Message 2 of 8
(2,821 Views)
Hi
how I can do this; in my state machine, I have enums and controls, and I need to initialize all of this and I also need to display messages depending on the choice to use. I do how in this case, when I puts everything in the cluster I can no longer define the choice of each enum to display the messages,?
I can't send data outside the state machine?
Message 3 of 8
(2,786 Views)
Hi Amelie,
You can change anything inside the cluster in each state.
You can change indicator data inside or after each state.
I don't know why you cannot do this in your VI…
Sure you can send data "outside the sate machine" to other loops/VIs…
Message 4 of 8
(2,770 Views)
Hi
Do you have an example of how I've ever worked on this?
when I put my control in a cluster it disappears from all the places where I call it, not only in the state machine?
I don't know how to resolve this problem?
Message 5 of 8
(2,766 Views)
How about uploading your VI for us to see?
Message 6 of 8
(2,757 Views)
Hi Amelie,
I didn't mention to place the control into a cluster, I wrote/asked to use a cluster to handle statemachine-internal data. One cluster to bundle them all, and you can write data from your control into this cluster…
Message 7 of 8
(2,755 Views)
You should take a look at this : Arrays and Clusters in LabVIEW.
Message 8 of 8
(2,754 Views)
