08-05-2015 11:03 AM - edited 08-05-2015 11:03 AM
What version of LabVIEW do you have?
Cheers
--------, Unofficial Forum Rules and Guidelines ,--------
'--- >The shortest distance between two nodes is a straight wire> ---'
08-05-2015 11:16 AM
Its 2012
08-05-2015 11:21 AM - edited 08-05-2015 11:22 AM
@sandy1234 wrote:
Its 2012
Ok, here's the above VI saved to 2012.
Keep in mind, you will need to edit it a bit to make it match the way your data comes in and the format of your spreadsheet timestamps.
Cheers
08-05-2015 11:24 AM
@sandy1234 wrote:
Its 2012
That snippet was made with 2014. So you will need to recreate the diagram by hand. It is a fairly simple diagram, so it shouldn't take you very long and you just might learn something.
08-05-2015 11:29 AM - edited 08-05-2015 11:29 AM
Cheers
08-05-2015 11:30 AM
Hi ,
yeah I believe it will work but I couldnt get two functions from the palette thatsy anyway I will try it in labview 2014itself... also the last vi is not fetchable as its saying created with later version....Thanks again
08-05-2015 11:32 AM
You have 2014, but you're using 2012 anyways?
Cheers
08-05-2015 11:36 AM
Hello James,
2013 is the running system which is in a remote place....also my laptop got crashed and installed 2012 ..currently am doing this in 2012
08-05-2015 11:41 AM
Okay, well it's not a hard VI to mimic, so have at it in whichever version of LabVIEW you would like. Those VIs have been around for a while.
Cheers
