installer for windows mobile 6 device mobile
i'm newbe in LabView. I have written a small programm for a windows mobile 6.1 device (psion ikon). I can run the exe file on the device.
So next i'm looking for a setup routine (installer) that installs the exe on the mobile device as a programm. so the user can find it under "Programs" and also can remove it with Programs remove. But on right click on build specifikations i can not find "Installer", only "Source distribution". With source distribution i just get the exe fole of the application, but i want something like "setup.exe".
How can i do this ?
Thanks for any help
Norbert Rieper
(3,157 Views)
Accepted by ISITEC_RIEPER
Hi Norbert,
the toolkit doesnt include any direct support to create an installer, but there are third-party products. Here I have a link for you:
http://digital.ni.com/public.nsf/allkb/E20C9D5F108150DF86256FF0004C56E4?OpenDocument
I hope this helps,
RMathews
Ramona Lombardo
Applications Engineer, NI Germany
Certified LabVIEW Developer
(3,149 Views)
Thank you RMathews,
thats exactly what i was looking for.
Norbert
(3,146 Views)
I use Pocket PC Installation Creator:
http://www.aperitto.com/
It is pretty good and allows you to make cab files or exe installers (run from PC). It is flexible and allows you to instll DLLs etc, custom icons
(3,139 Views)
