intensity graph background color black bu I like to have white
Hello:
I am trying to plot 2D time-frequency graph. The intensity grapk Background color is remain black whic is not good for report. How I can change, No clue from my side please help, would be highly aprreciated
Moin
Moin
(4,030 Views)
I don't have a thorough answer for you but I think I can point you in the right direction.  See the attached modified example VI.  By experimenting with the property node data you should be able to set the color for data values that are below a threshold to a color other than black.
(4,025 Views)
Hello: I dont how come I missed your reply. Could you please send the answer in LABview 8.5. I didnt able to open your answer.
Many thanks
Moin
Moin
(3,964 Views)
Hello Moin,
Here is a Knowledge Base article with the instructions for the proper property node to programmaticly change the background color of a graph.
http://digital.ni.com/public.nsf/allkb/925C4EEEFAFD68C78625720F0065869A?OpenDocument
M. Whitaker
ni.com/support
(3,946 Views)
Hi:
I have been trying for long time according to this instruction. it is not working for me. The back ground color is still black.
 If you please help me, I attached the code (NI 8.5) . May be something wrong that is beyond my knowlege.
Moin
Moin
(3,942 Views)
Accepted by laplace_transform
The background color of the graph itself is not black : the point is that most of the intensity values in your data are equal to zero, thus the corresponding points in the graph are black because of the Z color scale chosen 😉
Just change the color scale for intensities, with white for zero values, and it works (see modified attached code)...
HL
BTW, you don't need any flat sequence in the code...
(3,935 Views)
Many many thanks to you.
Moin
Moin
(3,914 Views)
