interpolate 1d array
Is this is interpolation array works as per Newton-Gregory forward interpolation formula.As i am not getting exact value in programming.kindly look into the attached pic for reference...as per formula i am getting 214.6875...but using programming i am getting 231.5...can anyone help me
Message 1 of 8
(7,650 Views)
Hi sanjay,
did you read the help for this funtion?
With x=0.5 you get the mean of the array element 0 and 1: 225 + 0.5 * (238-225) = 231.5…
Message 2 of 8
(7,630 Views)
Hi Gerd,
 as per  that function in LV what they have defined ,the answer is correct but ,in terms of mathematical equation ,i found answer was incorrect.
as per Newton-Gregory forward interpolation formula.......Interpolation function is derived from mathematics ,so when i started working theortically ,answer was not matching.kidly look into the attached pdf for reference
Thanks&Regards
Sanjay k
Message 3 of 8
(7,620 Views)
Hi sanjay,
In which way should the result be incorrect? Interpolate1DArray uses a simple linear interpolation as is clearly stated in the help!
What has "Newton-Gregory" to do with Interpolate1DArray?
Message 4 of 8
(7,617 Views)
HI Gerd,
can u explain me ....about interpolate and threshold array ....in terms of mathematical equation...bit confused how it works
Regards
sanjay k
Message 5 of 8
(7,594 Views)
Accepted by sanjayks066
It is linear interpolation, very basic algebra.
For a given X between x0 and X1, you'll get the value of Y = Y0+ (Y1 -Y0)*(X-X0)/(X1-X0)
Message 6 of 8
(7,591 Views)
thanks Ravens
Message 7 of 8
(7,585 Views)
The word "interpolation" is quite generic and does not specify any particular algorithm. There is "interpolate 1D array" that does a linear interpolation, but LabVIEW also has quite a few more advanced 1D and 2D interpolation algorithms in the interpolation palette. Maybe what you are looking for is in there, and if not, you can write your own and wrap it into a subVI. Looks like you have all the required formulas. Good luck! 😄
Message 8 of 8
(7,559 Views)
