is labview 5 compatible with Windows XP home and professional version?
Can i install labview 5.0 on a windows XP environment- home and professional version?
Also is labview 5.0 and 7.0 compatible with Celerons? Or is there any difficulty?
Please clarify
(2,887 Views)
They all work fine in these environs. The only trouble you may run into is temporary files not being accessible if the user logged in is not an administrator or the vi was created by an admin and a limited user tries to run it. This can easily be fixed by giving lower users permissions to use these files. The legacy versions of NI-DAQ do not run on XP though, you'll have to use a more recent version of them.
2006 Ultimate LabVIEW G-eek.
(2,887 Views)
