key navigation, defining own keys
i want to control some buttons on the front panel with the keyboard.
How can i use the cursors (up,down,left,right) for button control. In
the menu key navigation are only the F1, F2... and some other keys.
The question is how to customize the key navigation.
I really hope you can help me.
Jürgen
(2,511 Views)
You can't change the keys available to you for keyboard navigation. At least as far as I know. You can, however, make up your own using the keyboard functions that come with LabVIEW. There's an example that ships with LabVIEW that shows you how to do this. You will likely need to use an event structure-based architecture, or something similar.
(2,507 Views)
