keyboard
I cannot edit anything inputted from the keyboard. No mathscript nodes, labels, numberical constants nothing.
any solutions or do you just recommend a re-install
(3,430 Views)
If you can't edit with the mouse, as well, maybe the VI is locked: see Vi Properties->Protection.
(3,422 Views)
Accepted by Nadiafre
It's also possible you're in run-mode. Ctrl-M (check the menus) should toggle you between edit mode and run mode.
(3,398 Views)
