labview. Writing an equation inside a formula node
How would I write this equation chl= (4.9467*mv) - 0.3239 inside a formula node? Thanks
(3,693 Views)
(3,691 Views)
Accepted by EETG9000
You don't even need a formula node. An expression node would suffice. 😄
(3,676 Views)
Of course that can be done in pure LabVIEW code with only two primitives.
(3,668 Views)
... plus two diagram constants. 😄
(3,657 Views)
Assuming you have a formula node with an input labeled mv and an output labeled chi, I would enter it this way:
chl= (4.9467*mv) - 0.3239;
Hope this helps...
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,633 Views)
