labview. Writing an equation inside a formula node
How would I write this equation chl= (4.9467*mv) - 0.3239 inside a formula node? Thanks
(4,295 Views)
(4,293 Views)
Accepted by topic author EETG9000
You don't even need a formula node. An expression node would suffice. 😄
(4,278 Views)
Of course that can be done in pure LabVIEW code with only two primitives.
(4,270 Views)
... plus two diagram constants. 😄
(4,259 Views)
Assuming you have a formula node with an input labeled mv and an output labeled chi, I would enter it this way:
chl= (4.9467*mv) - 0.3239;
Hope this helps...
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,235 Views)
