labview- datalog/output file
The pleasure is completely mine.........as long as you rate the answers!!!Smiley Wink
Message 21 of 24
(1,007 Views)
Hi Hari,
Glad to have been of assistance to you.
All the best
Regards
Dev
Message 22 of 24
(999 Views)
have been reading thru the forum and found this posting. I am trying to read from mulitiple strain gages and am having no luck. your post indicates that this is possible but I dont follow you on how to add multiple channels with a comma. is this in the front panel drop down area or is this a field that i need to change in the diagram section. Any help would be appreciated.
Message 23 of 24
(969 Views)
I just click on the first channel I want to use and then type in ":lastchannel." For example if I want to use channels 0-4 in my SCXI chassis, I would specify: SC1Mod1/ai0:4. (Check in the Measurement and Automation Explorer for the chassis and module numbers.) Have a great day!
Marni S.
Message 24 of 24
(958 Views)
