03-21-2018 08:49 AM
Hello everyone,
during my intership i have a project where i have to add some data to an excel file which already exist, i have to use activex but no idea how to use it, is there some vi available where i can give a file and the coordinates of cells where to writte
Solved! Go to Solution.
03-21-2018 09:05 AM
Try This
03-21-2018 09:31 AM
thanks a lot, do you by chance have the vi so that i can dowland it ?
03-22-2018 02:47 AM
i don't manage to drag and paste, can somebody put the VI file please ? thanks in advance
03-22-2018 03:35 AM
Hi Louis,
left-click the image to start the image viewer of the NI forum.
Then you will see a download button below the image: save the image to your harddrive.
Drag the image file from your harddrive into an empty VI block diagram.
Finished.
03-22-2018 03:44 AM
well the probleme now is that i have the labview 2014, doesn't work with this file.
03-22-2018 03:52 AM
03-22-2018 04:24 AM - edited 03-22-2018 04:28 AM
thanks a lot, but it still doesn't work but i think it is an individual error (it will probably work on other computers), when i run an error occur , and when i open the excel file after it didn't change as expected and it is suddenly only lecture mode available
the error is error -2147352565 index not valid
03-22-2018 04:47 AM - edited 03-22-2018 04:47 AM
03-22-2018 04:53 AM - edited 03-22-2018 04:55 AM
i think i gave a valid one, i used the path button to specify the file, i don't know what i can do better
