labview excel with activex
Hello everyone,
during my intership i have a project where i have to add some data to an excel file which already exist, i have to use activex but no idea how to use it, is there some vi available where i can give a file and the coordinates of cells where to writte
using labview 2014, beginer on labview
Message 1 of 29
(21,767 Views)
Accepted by topic author louis293
Try This
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
Message 2 of 29
(21,752 Views)
thanks a lot, do you by chance have the vi so that i can dowland it ?
Message 3 of 29
(21,740 Views)
i don't manage to drag and paste, can somebody put the VI file  please ? thanks in advance
Message 4 of 29
(21,715 Views)
Hi Louis,
left-click the image to start the image viewer of the NI forum.
Then you will see a download button below the image: save the image to your harddrive.
Drag the image file from your harddrive into an empty VI block diagram.
Finished.
Message 5 of 29
(21,703 Views)
well the probleme now is that i have the labview 2014, doesn't work with this file.
Message 6 of 29
(21,700 Views)
Hi Louis,
here you go.
(You could state your LabVIEW version in your signature to aid other to provide VIs in the needed version…)
Message 7 of 29
(21,693 Views)
thanks a lot, but it still doesn't work but i think it is an individual error (it will probably work on other computers), when i run an error occur , and when i open the excel file after it didn't change as expected and it is suddenly only lecture mode available
the error is error -2147352565 index not valid
Message 8 of 29
(21,687 Views)
Hi Louis,
index not valid
The VI will select a certain Excel sheet: you have to provide a valid sheet name!
Message 9 of 29
(21,665 Views)
i think i gave a valid one, i used the path button to specify the file, i don't know what i can do better
Message 10 of 29
(21,659 Views)
