labview internal error memory manager.cpp line 406
I am running labview 8.5 code that i have upgraded from labview 4.0 and i encountered a memory manager  problem for only 2 tests. I am uploading log file and error pic.
timmy
(4,819 Views)
Hey Indo Asia,
The problem with this error code is that it refers to a large number of causes. From my research, it appears that this issue can be caused by a number of problems. To list a few...
1. Unnecessary local variables
2. Data flow issues
3. Nested While loops
4. Poor management of references
5. Stacked sequence structure in a while loop
6. Uninitialized arrays
7. Coercion dots
8. Error handling
I find it interesting that only two types (out of 5, I believe) causes this error. Perhaps figuring out what they have in common could better focus your trouble-shooting. Hope this gets you started.
Ben D.
Applications Engineer
(4,794 Views)
Is there any way to determine what vi caused the error?
For me this particular error only occurs when I run the full application, I have not been able to reproduce it in unit testing, and it is becomming a serious problem.
Can IMAQ and using image "references" cause this problem as well? (referring to point 4 in BenDAE's list if known issues)
If using IMAQ references can cause this, then how can it be avoided? - as far as I am aware I delete all images that are created, and trying to use a deleted image have so far in testing always reported an error...
Engineer, M.Sc. Autonomous Systems, Automation and Control of non-linear systems
Project Engineer @ R&D A/S
www.rdas.dk
(4,602 Views)
Hi ZcuBa,
Closing your IMAQ references is the recommended memory management stragety, and should not generate a memory manager error. The other error you mention, where you attempt to use a destroyed image, is expected behavior.
LabVIEW does provide tools to watch memory management and performance, you can find the Profile Performance and Memory tool under tools >> Profile >> Performance and Memory.
Documentation on the Performance and Memory profiler can be found here: https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/dialog-boxes/profile-performance-and-memor...
As this thread is several years old, you would have have better luck posting a new question to the forums describing your problem - it is unlikely that anyone else will see or reply to this thread.
-N
Staff Certification Engineer
(4,584 Views)
thanks
www.rdas.dk
(4,571 Views)
