labview sql query
Hi HI...I'm a student doing a project related to labview. My task is to creat a vi, typing a user name and password, to continue the whole VI.
As I'm a newbie to SQL query language, can anyone help me out about that??.. It's not like locking the VI with password
There is a button called user login in my main front panel...when u click it, a popup window will come out asking you a user name and a password. If the user name and the password is correct, then u can proceed. The problem is I'm stuck with database....
Help me out pls!!!
with regards,
Ray
(4,172 Views)
first, do you have the connectivity toolkit ?
V-F
(4,162 Views)
Hi Hi...yes I do have it and the attached file is what I did for my case.........now i'm stucking with the connection information...which is adding the "Microsoft Access File" to the VI and create a new VI of it. Sadly, it doesn't work out like I expected. It needs a .udl file and mine is .accdb file....Any idea of it?? Thanks a million
Ray
(4,157 Views)
Accepted by Ryamnod
You have two cases :
1) Connecting to database with string (link a string to connection information), and type something like this :
 Driver=SQL Native Client;server=IP.Add.re.ss;UID=userName;PW=****;Database=MyDatabase (it depends on your database)
2) use a UDL file (you can configure it to connect to your database, with specific format). Be sure that connection is successful with test button.
there is an UDL file that you can modify there : C:\Program Files\National Instruments\LabVIEW 2010\examples\database\Labview.udl
Edit :  In the connexion filed, you can set the path of a mdb file, and I think that you can give there the path of your accdb file.
V-F
(4,154 Views)
