labview test Q1
Which of the following statements is true regarding the use of Clusters
a.  Thje first object placed in Cluster is designated as elememnt zero
b. If you delete an element in a cluster, you must read just the order of tghe elements manually
c. Cluster elements are ordered based on their position in the shell.
d.  both A @ B
e. Both B @ C
I  xsay answerr is "A"
am i correct?
Message 1 of 35
(6,868 Views)
Instead of asking whether your answer is correct, why don't you just open LabVIEW and try A, B, and C? Create a cluster and add 3 elements. Look and see which one is element 0. Delete an element. Look at the element numbers. Move the elements around. Look at the element numbers. The test is to see how much basic knowledge of LabVIEW that you have. You gain the knowledge by actually using it.
Message 2 of 35
(6,853 Views)
I agree, I did some of that b ut I lack confidence in what I am seeing.    Then sosme of the things tghey ask about I just do not know how to do and no one to show me.  When  I take these tests it does not inidacte whihc quyestion I answerr correct plus what correct answer is.
Not easy way to lkearn
Message 3 of 35
(6,845 Views)
yes
Message 4 of 35
(6,836 Views)
i hope there are some guys on this board that actually want to help people with less  programming skills, ratrher than showing off how freaking smart they are.  If your arrogant, please do not help me.  On the other hand, with this tuff economoic situation, some folk may understand we al need help of various sorts throught our lives.
I do not know how to work this board i do know the culture and I can make as man y threads as I wnat to trach my issues.  Noone makes the ruilkes here except NI, and they toild me what I am doing is fine
Message 5 of 35
(6,797 Views)
With that attitude you just lost your support from the LabVIEW community.
Visualize the Solution
CLA
LabVIEW, LabVIEW FPGA
Message 6 of 35
(6,793 Views)
I don't think anyone here now cares whether you pass or fail the exam. My response was intended to help you learn LabVIEW itself and doing that seems to be the whole point of these boards.
Message 7 of 35
(6,777 Views)
i see some people think they arfe the king and decide who gets to play and who does not.  I am sure tghey whole world of labview programmedrs are not a bunch of sheep and play follow the leader.   I think I will contact my NI account person and have them assign a mistress  to admisister some spankings to wise guys.  Seems it is needed
Message 8 of 35
(6,751 Views)
by the way, I am just defending Test Taker  Since no one else seesm to be.  Test Taker, I will answer your questions or get them answered.  I have not been drininking their KOOLADE
Message 9 of 35
(6,749 Views)
The reasons these questions are n ot being answered is that the long time [posterts here are afraid to answert dffor fear of being EXPPOSED for not knowing something Basic if they chose the wrong selection.  Likely soime real insecure posters out there
Message 10 of 35
(6,746 Views)
