labview
Respected Sir/Madam,
We are doing our final year project on labview.We are using DAQ assistant to simulate our project. I would like if there is any possibilty to create a new channel in the "add  channel" list just like pressure is builtin. Is there is any possibilty that we could add a channel named Flow into the driver. Please respond immediately. I guess it is not possible, but I would like to get confirmation. My guide is just torturing me over this. He wants us to include a  airflow measuring instrument just like the pressure bridge used to measure pressure directly.
Message 1 of 27
(5,123 Views)
(Every single post here is about LabVIEW, so to would clearly help of you would use a more descriptive post title!)
Everything is possible, but you need to be a bit more specific. You talk about "simulate". Are you using simulated instruments or real instruments? What do you mean by "driver". Have you used MAX?
Please reply immediately! 😮
Message 2 of 27
(5,115 Views)
we are using simulated device only. We are using MAX and selected a DAQ card and DAQmx for configuring it. What I would like to know is in the the available channels list, we have a pressurebridge for measuring pressure ,strain measurement etc., similarly can I add myself a measurement mode for airflow, like an airflow meter.
Thanks for replying. Please respond
Message 3 of 27
(5,062 Views)
off course you can add a channel to a task.  We do it all the time 😉 .
Take a look at this thread and it might help you out on how to do things.
Kind regards,
- Bjorn -
Have fun using LabVIEW... and if you like my answer, please pay me back in Kudo's 😉
LabVIEW 5.1 - LabVIEW 2012
Message 4 of 27
(5,048 Views)
We too doit, but what i wouldlike toknow is I want the airflow measurement to be added in the channels list just like pressure. IN the LAbview 2010 software we have various channels like strain measurement in the same manner I want to have an airflow measurement device in that list
Message 5 of 27
(5,033 Views)
but strain measurement is a specific measurement, and needs to be dealt with in a different way.  Airflow measurement is a normal analog input, isn't it?  Which can be a voltage or a current depending on the output of your sensor.
Kind regards,
- Bjorn -
Message 6 of 27
(5,031 Views)
yes i know but my project guide is requesting to have that as a specific measurement in the list. Please tell me can it be done by us or its in the software itself: built in .
Message 7 of 27
(5,024 Views)
so you want to be able to select that type of measurement from the Daq assistant?  so more or like this ?
Kind regards,
- Bjorn -
Message 8 of 27
(5,021 Views)
Yes. you got that spot on!!!!!. pleasetell me is it possible or not.My guide is ............. me.
Message 9 of 27
(5,018 Views)
Here is a document that helps you step by step.  Look at figure 5.  It shows you how to add a channel by clicking the "+" button.  you can assign a name to the channel and configure it.
If you want to add it to the list shown in figure 4, that can't be done, because it's just a plain voltage or current.  you will have to assign a name in figure 5
Kind regards,
- Bjorn -
Message 10 of 27
(5,014 Views)
