labview
k , but cannot I have a direct measurement for airflow in cfm like pressure bridge measuring pressure in psi. I donot want measurement in voltage and convreting via scaling to cfm. Just tell me is it possible what I am asking. My project guide is asking for it. I think its not possible. But please guys help me out on this if it is possible help me know about it.
Message 21 of 27
(1,329 Views)
You are not understanding fundamental sensor operations. Sensors measure voltage. They do no measure engineering units like cfm. You need to convert a voltage to a cfm with a formula. That's the way the universe works. This has nothing to do with the DAQ Assistant. Please spend some time reviewing how sensors work.
Message 22 of 27
(1,327 Views)
This is very simple.  The answer is NO.  Go tell your guide I said so. Smiley Tongue
I'm assuming here that you are asking if you can modify the DAQ Assistant to add your own input types.  If you need to do that, it's time to leave the baby pool (DAQ Assistant, Express VIs) and learn how to swim (LabVIEW primitives).  You can write code to do what your guide wants with full LabVIEW but the DAQ Assistant is for beginners and doesn't have that capability.
P.S.: Maybe you shouldn't mention to your guide that it can be done at all. Smiley Wink
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 23 of 27
(1,320 Views)
Thank you dude. Thankss for understanding my problem. I will surely convey ur msg to him
Message 24 of 27
(1,305 Views)
Tell him after you've added the measurement.
Message 25 of 27
(1,302 Views)
You're welcome, "dude".
Please try to be a little more professional on these forums. Thanks.
Message 26 of 27
(1,294 Views)
My bad. From next time onwards I will surely.
with regards
pavan
Message 27 of 27
(1,279 Views)
