labview
he wants us to add "airflow measurement " in the list shown in the image below.
Message 11 of 27
(2,819 Views)
Yes but even the measurement of airflow is done in volts itself but not in cfm. Iwant the airflow to be measured in cfm just like pressure is measured in psi in pressure bridge in DAQ ASSISTANT.
Message 12 of 27
(2,818 Views)
Then you need to create a scale that converts volts to cfm.  That is the purpose of the custom scaling section to the lower right of the DAQ assistan.
Message 13 of 27
(2,801 Views)
thanks for the response.
I have used that but it is not possible to create a custom scale measurement in DAQ assistant by ourselves is it??
Message 14 of 27
(2,797 Views)
If you have actually used that then you should certainly know that it is possible. Your question is silly.
Message 15 of 27
(2,791 Views)
Did you try clicking on the "Custom Scaling" dropdown? And see the "Create New..." item?
Please try things before asking questions on the forum that can easily be answered by a little effort on your part.
Message 16 of 27
(2,787 Views)
i have tried it guys. What i meant by custom scaling measurement is that can I add my own measurement device  ( air flow measurement) in the drop down list of channelsjust like pressure bridge, LVDT, starin measurement etc.
Message 17 of 27
(2,782 Views)
You aren't paying any attention to the answers and you aren't really paying any attention at all to the DAQ Assistant screen.
Message 18 of 27
(2,774 Views)
dude i totally got u and i tried it. I am asking about having direct airflow measurement in DAQ assisatant not like using sensor voltage signals. I would llike to have direct airflow measurement device added to it is it possible.
Message 19 of 27
(2,769 Views)
What are you talking about?
The data acquisition device reads voltage.  You need to convert voltage to air flow (CFM).  You use the scaling for that channel to accomplish that based on the conversion factors of your sensor that says so many volts equals so many cubic feet per minute.
Message 20 of 27
(2,765 Views)
