I understand how to compose legible block diagrams and
front panels for a given screen resolution,
but I am wondering how to make Labview's built-in examples
display legibly without having to change my screen resolution to
800x600 with normal fonts.
There seems to be no easy way, as far as I can see,
to quickly resize and relayout and
existing example vi so that text doesnt overlap and icons
aren't all crowded together.
I have played with the alignment controls, but none of them
seem to be useful for relaying out a screen on a different
grid spacing.
Everytime I open an existing Labview example vi, it looks
like a bunch of gobbledygook, text boxes are overlapped and
illegible, icons are crowded together, wire connections
are impossible to see, and I waste a lot of time
trying to move stuff around to make it legible.
I gotta believe they cant have intentionally left out such
a basic feature common to any other CAD program such as
schematic capture etc.
Do they really want us to always use 800x600?
Am I being stupid in trying to run 1024 or greater
with large fonts on a 15" LCD?
>> I always define a front panel default font of fixed size. In your
>> case, you could try to select all front panel objects at once, then go
>> to the font dialog and select a defined font, e.g. Tahoma 13pt. To
>> play with other sizes, keep it all selected and press ctrl-/ctrl= to
>> decrease/increase the font size.
>> If your icons are getting "indecipherable", it means that your screen
>> resolution is to high for the monitor size. There is no use running
>> 1600x1200 in a 15" screen. In an ergonomically selected display, the
>> screen size must match the resolution. (e.g. 1024x768 on 17",
>> 1280x1024 on 19", etc.). The size of a pixel should be rather
>> constant.
> if I turn on extra large fonts in Windows, then the Labview
> VI screens become pretty much illegible as all the text overlaps
> the controls and each other.
> Is there any way to do an automatic re-layout of the screen
> so the text no longer overlaps?
> Also, some of the icons are pretty indecipherable on hi-res monitors,
> is there any way to zoom the icon size, or load a hi-res version of
> the icons?
