lauch a shortcut to my .exe with parameters
Hi guys,
I would like to know if it is possible to put parameters after the "target path" in the shortcut to my .exe to lauch my application.
i.e :
Shortcut 1 :
Like "C:\labview\MyAppli.exe" /File_Config_1
Shortcut 2 :
"C:\labview\MyAppli.exe" /File_Config_2
Then read good file config in my appli.
(3,249 Views)
Accepted by remvu
There is an example shipped with LabVIEW called "CommandLine" that demonstrates how to do what you want.
(3,235 Views)
perfect thank you !
(3,230 Views)
