launch EXE application using HTTP
Hi All,,
Is there a way to launch a LabVIEW EXE via HTTP protocol?
Currently I am using ActiveX to launch the EXE from other programming languages lile VC++ or Python but as I now have to port my application to Mac, I wonder if there's a solution to the problem which is platform agnostic.
Ritesh
(3,575 Views)
Accepted by LVCoder
Hi Ritesh,
isn't it the easiest solution to call a LV EXE from the command line? That should work in each environment…
(3,567 Views)
@GerdW wrote:
Hi Ritesh,
It defnitely is. Thanks!
(3,538 Views)
