line in waveform chart or graph
There are 4 field where the user insert data.
I want use data inserted by user and create a line in a graph or waveform.
Ex. 3000
2000
1500
In the graph or waveform ( in the Y axis) I want create a line with the values 3000, 2000, 1500
tks
Message 1 of 19
(7,111 Views)
Do you want a vertical or horizontal line?
- there is always an easy way, but it is always the hardest to find
Message 2 of 19
(7,107 Views)
Both..vertical and horizontal...
Many thanks
Message 3 of 19
(7,104 Views)
In the case of a graph you can add cursors who's line styles have both horiz and vert lines.
Cursors are not availabe on Charts (sorry).
Ben
Message 4 of 19
(7,100 Views)
an example or picture of what you are trying to do exactly would help. Or just go with the cursor idea, that would work just fine.
Message 5 of 19
(7,098 Views)
Follow attached what I trying to do.
Remember that 3000, 2000, 1000 and 85 are data entered by user.
Tks
Message 6 of 19
(7,094 Views)
Hi muganga,
you can write it as values into your graph. see the attached picture for an example.
Mike
Message 7 of 19
(7,089 Views)
MikeS81
But what about the datas from my sensor? How plot the values coming from the sensor? Is the number 85 a vertical line?
Tks
Message 8 of 19
(7,052 Views)
Hi muganga,
no this are all horizontal lines. Did you think about an x-y-graph?
Mike
Message 9 of 19
(7,050 Views)
Yes, I was thinking about x-y graph coz as Ben sugest in his post, graph we can use cursor.
Many thanks
Message 10 of 19
(7,045 Views)
