line in waveform chart or graph
Both horisontal and vertical can be applied by adding additional arrays to the graph
Horisontal are constants (arrays with same elements).
Vertcal are arrays with "-infinity"s before the leap, than "+infinities".
This works!
Message 11 of 19
(2,607 Views)
what I expect is:
Message 12 of 19
(2,601 Views)
Exactly! Just initialize arrays with size the length of the graphing array and elements all=3000/2000/1500!
They will show up immediately, just check their colors
Message 13 of 19
(2,589 Views)
How can I display 0,0 in the graph?
Tks
Muganga
Message 14 of 19
(2,565 Views)
turn off the auto-scaling, or play with scales through with corresponding properties
Message 15 of 19
(2,537 Views)
How can I divide axis X in equal parts. I mean, in axis X I have 0, 1 and 2. I want is 0, 0.2, 0.4, 0.6, 0.8, 1, 1.2, 1.4, 1.6, 1.8, 2
Follow attached drawing I would like to have.
Tks
Message 16 of 19
(2,500 Views)
How can I divide axis X in equal parts. I mean, in axis X I have 0, 1 and 2. I want to divide in  0, 0.2, 0.4, 0.6, 0.8, 1, 1.2, 1.4, 1.6, 1.8, 2
Tks
Message 17 of 19
(2,500 Views)
Hi golubovski,
You have mentioned that--
" Both horisontal and vertical can be applied by adding additional arrays to the graph
Vertcal are arrays with "-infinity"s before the leap, than "+infinities"."
Could you please give me an example of how to generate a vertical dash line? (I tried, but I failed. The value is input by user, and the line is not the cursor line)
Thank you very much.
Message 18 of 19
(2,303 Views)
Could you please give me an example of how to generate a vertical dash line? (I tried, but I failed)
The x and y values are input by user, and the line is not the cursor line
Message 19 of 19
(2,278 Views)
