local vs property node
what is the difference between local variables and property nodes concerning best practices and performance  ??
James
- James
Using LV 2012 on Windows 7 64 bit
Message 1 of 11
(32,556 Views)
If possible, you always want to pass data to/from your front panel controls/indicators with wires.  If this won't suffice (parallel loops, e.g.), then you will want to use locals.  Try to avoid using the "Value" property unless you must write to your controls/indicators in a subVI.  The "Value" property is very slow compared to locals due to threading issues associated with property nodes.
Hope this helps,
-D
Message 2 of 11
(32,550 Views)
Since you compare the two in one sentence, you must mean "Value property nodes". 😉
As Darren said, property nodes are expensive. Check out my speed comparison VI in this old thread:
(Of course if you need to write to a signaling value property in order to fire an event, a local variable won't work. You need the property node.)
Message 3 of 11
(32,536 Views)
Hello all,
To take it one step further, the speed hit comes from the fact that these items run in the UI thread along with all of your other user interface actions (speed), and copies are always made of the data (performance AND speed)!  Check out the "LabVIEW Performance and Memory Management" tutorial -- while a little old its concepts are still dead on and it does a great job of explaining the details of these issues.  If you need to pass data from/to parallel loops or sub-VIs consider putting the data in some sort of container (like a single element queue), and passing the container around.
Hope this adds just a little more insight!
Message Edited by Travis M. on 02-08-2006 02:21 PM
Travis M
LabVIEW R&D
Message 4 of 11
(32,509 Views)
Really good Thread thanks
Message 5 of 11
(29,233 Views)
Hello travis could you please pour in some more information on Property node concept and whn can it be best used?? Thanks in advance.
Message 6 of 11
(28,161 Views)
Most of the threads address time penalities writing values, not reading them.
In a new app I am reading the propert value of  "STOP", as the node has an error cluster input.
That extra input helps with Data Flow paradigm.
Also I can "OR" the nodes error cluster output and "STOP" to a loop termination.
So what's the cost compared to encalsuplating "STOP" in a sequence or case structure?
Message 7 of 11
(24,832 Views)
You can test it yourself.  Oviously the property node is far worse.
Message 8 of 11
(24,824 Views)
Your use of a property node also precludes the use of latch action, which is the typical mechanical action of a stop button. What does the button do? What is the rest of the code architecture?
We cannot really tell without seeing the entire diagram.
If this is a toplevel stop to end the program, I would eliminate it anyway and use an event structure for the panel close event. It is not normal or intuitive to close an program with a special stop button in some poorly defined panel location, but everybody knows the meaning of the [X] in the upper right. You can always discard the event and handle special shutdown code. You could for example enqueue the stop command at the opposite end in that event case.
You can do that in a small parallel loop that just sits there, but enqueues an exit command if the user tries to close the panel.
Message 9 of 11
(24,810 Views)
They are Test Methods for IP. So no, I can not share the APP.
The Event X close suggestion is useful. I will have to try it some time. Right now, I have no need for it.
I want to avoid using the ABORT button, and do error processing, hence the queue redirection to Exit State.
Anyway I did do my own testing, and feel like I'm goofing off....
Message 10 of 11
(24,767 Views)
