08-02-2007 06:02 AM
08-16-2007 10:01 PM
08-17-2007 02:37 PM
08-19-2007 08:35 PM
Hi Mikeporter,
Thanks for the response.
Yup, you're right, I ty to simulate as the code did, although I do able to collect the data but fail to get back the final result as the code did, means that i get back distorted signal instead of pure sine wave. I also try work to create the dll for the analysis part (invert frame), seem it crash with the LV. I had successful to create dll for the last part, from .bin format to .wav format and display on graph.
Simon76
08-21-2007 05:05 AM
I able to solve the problems and get back the sine wave signal.
Once, thanks for the helps and advice.
regards,
Simon76
08-21-2007 06:28 AM
08-22-2007 11:01 PM
08-23-2007 06:39 AM
08-23-2007 08:22 PM
Yup. You're man. What I want is to create or replace the file and now I get back the 32K data files. Thanks alot.
As I have create a dll to convert bin file to wave file, so all my data need to save as bin format file. Previously, i have try purely LV to create wave file by add header format to my compile data but seem not success, and i gonna to look at this issues again..
Once again, thank for your help.
regards,
Simon76
