measuring pressure
heyyy guys i been working on my graduation project i need to measure the pressure with mpx5700dp sensor using the arduino board and labview i made this block diagramme where i converted the voltage into pressure using the convertion function  and displyed it on the graph it on the graph also i created a thingspeak server to send the the data and stock it there the thing is i'am not sure if my work is correct ... i need someone to cheek it pls before i present it
Message 1 of 15
(3,801 Views)
You did not attach anything for us to "check".
Message 2 of 15
(3,797 Views)
how about now ?
Message 3 of 15
(3,786 Views)
Well, now you attached the same file twice....
Message 4 of 15
(3,776 Views)
lmaoo i'am sorry .. my supervisor is not familiar with labview so i'am basically working alone with no guidance.. the thingspeak part is working  i just need to check if that is the right way to display the pressure measurment on the graph ..
Message 5 of 15
(3,767 Views)
is it correct or do I need to change some things ??
Message 6 of 15
(3,711 Views)
Accepted by ihebz1
Since we don't have your hardware, we cannot "check" functionality, of course. Does it work?
OTOH, we can comment on the programming layout and logic:
  • Your on/off button does nothing
  • your LED is not connected, so why is it in the loop?
  • Why is there a file path control?
  • Your "5" constant should be orange.
  • "waveform chart" is not a useful label.
  • "Slide" is not a useful label. What is its purpose?
  • Property nodes only need to be written when their inputs change, not constanty.
  • What determines the loop timing?
  • Why does your HTTP "train" have no inputs and why do you write your data using a "get" reqeust?
  • Why do you concatenate two string constants? Wouldn't it be easier to have a string constant with all of it?
  • Your code runs until the time has elapsed. Don't you want a way to stop early? How about if an error occurs?
  • Your cases of the big case structure differs only by a  string constant. Everything else belong outside the case structure.
  • What determines the loop rate of the while loop? I don't see any reasonable pacing.
  • Currently, your code is a "downhill worm" where little can be done once it is running and the result is irreversibly lost if there is e.g. a problem opening the file.
  • A proper program here would be a state machine that start up in an idle state and never stops until closed. Having to run the program with every new test is not reasonable.
  • A front panel with things scattered all over the place and using controls of different styles is just plain ugly and confusing.
Message 7 of 15
(3,694 Views)
the graph thing how it is not useful like how how I'm supposed to display the measurements
Message 8 of 15
(3,687 Views)
Accepted by ihebz1
The chart is useful. The label "Waveform chart" is not useful. Change the label and call it something that makes sense in relation to the measurement. ("Pressure chart" maybe.)
Message 9 of 15
(3,675 Views)
and the loop timing how I'm supposed to determinate the value of it (from the datasheet)??
Message 10 of 15
(3,671 Views)
