media
Hi enzo78,
do you call this vi in another vi? Why do you write 0 into the chart if the loop runs, and only ones, if the loop will stop, the real value?
Mike
Message Edited by MikeS81 on 05-16-2008 02:11 PM
Message 11 of 13
(604 Views)
Hi enzo78,
here is your vi without the use of local variables. Can you show which value you want to see in the chart, please?
Hope it helps.
Mike
Message 12 of 13
(599 Views)
Hi Mark
At moment I write 0 to the chart if the loop run, and the average if it stop, and it is ok.
So I need in the chart the value of the average in function to the date and hour of the registration, such as an istogram...
Message 13 of 13
(588 Views)
