memory is full
Unless your array is extremely big, this shouldn't be a problem.
My guess is that your "step" is 0, and that division by 0 generates NaN, and initializing an Array to NaN size causes this error.
Another option is that "step" is a very small number, causing the array to be very large and running LV out of the memory it needs.
___________________
Try to take over the world!
Message 11 of 15
(1,839 Views)
how big is #points?  Depending on the RAM of your computer, there is a limit to how much memory you can use in your VI.  Memory is deallocated only after the whole VI finishes running, so all the controls and indicators (including the 8 arrays you created -- 7 you stored in controls, 1 was auto indexed and left unconnected at the end) takes up memory.  Try lowering #points and using the Profile Performance and Memory option in LabVIEW to anaylsis the memory usage of your VIs.  Look under "Profile Performance and Memory window" in LabVIEW help for more information
Message 12 of 15
(1,831 Views)
I would like to make one correction to my previous post - initializing to NaN probably coerces the value to the max I32 value, which makes the array very big, hence not enough memory.
___________________
Message 13 of 15
(1,811 Views)
Hello Devchander,
I have used an empty array as you recomended, it is working perfectecly.
Benio
Message 14 of 15
(1,798 Views)
Hi Benio,
Good to hear that your problem got solved!
glad to have been of assistance
All the best
Dev
Message 15 of 15
(1,786 Views)
