menu reference
In my subvi, I am trying to get the main vi's menu's reference, so that I can modify the main vi's menu with vi such as Set Menu Item Info.  How do I get the reference in a subvi?  Is there a property I can use?
Kudos and Accepted as Solution are welcome!
(3,575 Views)
Some quick searching around leads me to believe that this isn't available.  You can get the path to the main VI's menu, but not a reference to the menu itself.  If knowing the path to the .rtm file doesn't help, can you put the main VI's menu reference into a global (ahem) that you can read from the sub VI?
Jim
(3,564 Views)
Accepted by jyang72211
Any reason not to simply pass the menu reference from the main VI to the subVI?
(3,557 Views)
Darin - No reason.  I had no idea what I was thinking.  Thanks for pointing that out.
(3,551 Views)
