multi channel analog output
Hi All,
I  want to generate sine wave at 10 KHz simultaneously for 4 channels with attached vi.
The example is for 1 channel , i want to do it for 4 channel,
any hints,
Shrek
(2,391 Views)
The example is for 2 channels and to get 4, you just need to specify them in the channel control.
Even though you've been using LabVIEW for quite a while, you should look at the DAQmx Getting Started tutorials.
(2,387 Views)
