multiple needs on gauge/meter
Is there a way I can programmatically determine if a gauge/meter has more than one needle?  All I have is the ClassID and possibly the CtrlRef.
Message 1 of 13
(5,066 Views)
hi faustina,
  The gauge's property NumSliders will give the count of needles...
Thanks and regards,
srikrishnaNF
Srikrishna
Message 2 of 13
(5,060 Views)
I'm running LabVIEW 2009 SP1.  I don't see this property anywhere in LabVIEW Help.
Message 3 of 13
(5,037 Views)
Can be done like this.
21305iB6E55F4B6900E5AD
Tim
GHSP
Message 4 of 13
(5,031 Views)
hi,
  21323iECB3FCFD4AB30A41
Like this...
Thanks and regards,
srikrishnaNF
Srikrishna
Message 5 of 13
(5,010 Views)
The blue in the top bar of the property node indicates that is a property only available if you have scripting installed.
Message 6 of 13
(5,004 Views)
Scripting is not a feature in LabVIEW I'm familiar with.  I have the the professional developmental version.  What toolkit/module do I need to install?
Message 7 of 13
(4,989 Views)
Why are you ignoring the example from aeastet? Did yu even try it?
Message 8 of 13
(4,982 Views)
Allow me to take the liberty of using my own snippet tool so that aestets' nice solution is not mangled by the LV snippet tool.
21419i91799B16E927CCA7
Look like something worth trying now?  Not that you shouldn't install scripting, for that see the LabVIEW API page.
Edit: I see you only have the CtrlRef, then you really should be using aestet's solution....
Message 9 of 13
(4,971 Views)
See this first:  http://forums.ni.com/t5/LabVIEW/What-is-Labview-scripting/m-p/824083
Bottom line: If you don't have a good reason to work with LV scripting... don't.  And it looks like you have a simple solution Smiley Happy so why not just use that?
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 10 of 13
(4,960 Views)
