multiple needs on gauge/meter
I would use the DigDisp array if I could guarantee that its size was the number of needles.  I thought its size was dependent on IF the digital display for the needle is visible.  If a DigDisp is automatically created when a needle is created, then this is a great solution!
Message 11 of 13
(688 Views)
As far as I know the number is the same whether or not the needle's digital display is visible.  Try it and see for yourself, I can't offer any guarantees.
Message 12 of 13
(679 Views)
As Darin said, it does not matter if the dislay is visible or not and if you had simply tried it, you would have known that already.
Message 13 of 13
(673 Views)
