multiple transfer functions in one bode graph
How can I plot multiple transfer functions in one bode graph? Can someone point me to an example
(3,793 Views)
Accepted by Li Nan
Li,
First, if you use the mouse to grab the top of the plot legend and "pull" it up, multiple plots will appear.  The graph node will expect multiple inputs.  Does that solve your problem or is there more to it?  If it doesn't it would help if you would post the code you have so far.
-Matt Bradley
************ kudos always appreciated, but only when deserved **************************
(3,780 Views)
