myrio
Many thanks to those who helped me. I have installed Vision Development module successfully. Unfortunately now I am facing a new problem. I programmed a color recognition code and a motor control code. Now I want to achieve a goal: when the color recognition code recognizes green, it can control the motor rotation. I have no clue about this problem. I hope you can provide suggestions. If you can provide Specific code I would be very grateful.😀
(1,040 Views)
Easiest way to pass your assignment, I mean problem, would be to copy both into one VI and connect the loops with channel writers and readers. You left open how your motor should get controlled.
Actor Framework
(1,010 Views)
