negation 0 to 1
I love how these simple questions often turn in a race to the bottom, who's gonna provide answer with the least functions/smallest size 😄
Message 11 of 18
(2,653 Views)
code golf 🙂 https://www.youtube.com/watch?v=MqZgoNRERY8
@rolfk wrote:
@crossrulz wrote:
@GerdW wrote:
What about this:
y := 1 - x
I was thinking to add 1 and then AND with 1.  But yours is simpler still.
x = (x+1) && 1
a sparse occasion to use labviews expression node ...Gerd's approch is fairly easy to convert to primitives
the bitwise && gave me a little struggle to convert to primitives -
but wait, the 'formula node' and 'expression node' is based on C, and it turns out, && must be changed to &, as rolf predicted. nice!
Spoiler
Message 12 of 18
(2,634 Views)
Because choice is so much fun, here my "limited" selection of options:
Caveat: they only work fine if the input is guaranteed to be in the range (0, 1). Other values will cause different results, some of them more intuitive than others. This is where Christian Altenbach's post comes in: we need to know the conditions and requirements for a proper selection of the various options.
And the -x + 1 only works for signed integers. The -x node refuses unsigned integers on its input, a sensible limitation. Interestingly the formula node version of this does not only not have this limitation but effectively still produces the right result. Apparently it promotes the value to a signed int internally and then converts it back to the input data type.
And I think I discovered a strange bug in the snippet generation. This is the actual VI block diagram from which the snippet was generated:
Anybody can notice the difference in two of the indicator labels?
Rolf Kalbermatter  My Blog
Message 13 of 18
(2,625 Views)
Isn't it just a simple LabVIEW rule: Don't have two indicators or controls with the same label?
By the way I see four differences.
Message 14 of 18
(2,605 Views)
It's not something that is normally enforced. Yes, if you create new controls they will be made having unique labels but nothing prevents one from renaming them back. Seems the snippet tool is kind of recreating the diagram in the background through scripting to get the VI code. Possibly because I did not save the VI?
Message 15 of 18
(2,597 Views)
<Offtopic> Similarly, I occasionally run into issues when just doing a copy/paste of graphs into e.g. MS paint. If a graph is set to autoscale, but the axes have been manually panned or zoomed, the pasted picture is autoscaled to the data again and thus looks different than on the front panel. Tedious! </oftopic>
Message 16 of 18
(2,565 Views)
Didn't even know you could do that, i normally just print screen stuff like this...
Message 17 of 18
(2,550 Views)
Yes, LabVIEW is doing something with the code of the snippets. As you can see in my post here, at recipe 06 I overlooked the change of labels 😫, later I  tried to give these labels unique names by a leading underscore, hidden (well, badly) by the terminal, as can be seen at 07 & 08.
A space will be trimmed and the label will then be renamed.
Greets, Dave
Message 18 of 18
(2,541 Views)
