negative number in formula node
good day.
I am trying to find information on how to include a negative number in the formula node.
thank you
Message 1 of 12
(2,522 Views)
Put a negative sign before the number...
Message 2 of 12
(2,499 Views)
Click on the border of the formula node, then click the key on the keyboard just above the arrow keys that says "Delete".  Problem solved.  😂
aputman
Message 3 of 12
(2,492 Views)
thank you I see in the example you provided that I was missing a space between the function and the minus sign.
Have a goo day
Message 4 of 12
(2,478 Views)
Have a goo day
I generally don't like goo days (too messy).
Message 5 of 12
(2,472 Views)
A space is not required.
aputman
Message 6 of 12
(2,466 Views)
As some have already hinted, maybe the real solution is not to use a formula node at all. There is really never a compelling reason for them.
Can you take a step back and explain what you are trying to do?
Message 7 of 12
(2,417 Views)
There are compelling reasons NOT to use them , though, like:
  • They are orders of magnitude slower than if you created the same code using native functions.
  • You have to worry about syntax (exactly like what the OP is having trouble with).
Of course, this post isn't aimed at educating you, Altenbach.  😉
Bill
CLD
(Mid-Level minion.)
Message 8 of 12
(2,397 Views)
"There is really never a compelling reason for them."; "They are orders of magnitude slower than if you created the same code using native functions." - I agree that one is never forced to use the Formula Node: anything that can be achieved inside the Formula Node can of course be achieved using lower-level primitives such as Add, Multiply, Exponential, etc. I also agree that Formula Nodes execute more slowly than the primitives, and, for this reason, they need to be used judiciously.
But for me there is a compelling reason to use them: readability. Formula Nodes are the best option when implementing large, multi-line, complex formulas. Especially when those formulas are defined in a document, such as a PDF that the customer handed us. The code inside a Formula Node can be made to correspond one-to-one to the formula as defined in the customer's PDF. This leads to code that is much easier to understand, verify, and maintain.
It is a bit of a shame that performance needs to be traded off for readability, or vice-versa. Ideally both readability and performance would be achieved simultaneously.
Message 9 of 12
(993 Views)
(Old thread, I know)
Formula nodes can be quite competitive in speed and that's why I didn't touch that topic.
I do have some kind of undiagnosed "formula node dyslexia" and have a hard time to "follow the flow" unless they are very simple.
Message 10 of 12
(989 Views)
