network streams
hello,
i want to send data periodically from a host to realtime targets via network streams. the data types delivered by the host are unfortunatly not scalar but rather: a cluster of enums, a cluster of different elements and two arrays of clusters. i was wondering if it works to have multiple streams (4 parallel streams) doing the job?
thanks in advance
(4,179 Views)
Network streams will accept any data type.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(4,167 Views)
... except classes.
(4,159 Views)
thanks for the reply. but what about parallel streams? is it possible to establish multiple network streams (write) from the host to the same real time target?
(4,156 Views)
Yes, streams are named pipes. As long as each device provides an end point for the stream you can have multiple streams.
Mark Yedinak
LabVIEW Champion
(4,151 Views)
Accepted by labviewette
Hi Labviewette,
As others have said, you *can* set up multiple streams for each data type if you want.
However, there is overhead that comes along with this and what happens if you need to add more data types?
How many streams will you end up needing?
I prefer to use one stream for writing and one for reading from the RT target.
The streams are configured as an array of 2 strings.
The first string defines the data type.
The second string is the desired data flattened to a string.
When data is received, just check the first string and feed it to a case statement where the data (from the second string) is "unflattened".
This method has less network overhead and is extensible.
steve
Founding (and only) member of AUITA - the Anti UI Thread Association.
(4,142 Views)
