05-22-2007 05:21 PM
05-22-2007 09:32 PM
05-23-2007 04:46 AM
05-23-2007 03:25 PM
Make sure the DataSocket Server is running before running your vi. You can set your server by giong to Start >> Programs >> National Instruments >> DataSocket >> DataSocketServer. I suggest you try running the Front Panel DataSocket Read.vi and Write.vi from the example finder and see if you can get it to work. If you need to set up the Datasocket connect simply right-click the waveform chart >> properties >> scroll to the right and define the path in the Data Binding section. Just make sure to define the proper IP address in the Read.vi to be able to read from the Write.vi.
Can you elaborate on your program crashing when sending values from your DAQ device? What kind of errors do you get? Is there an error code? What DAQ board do you have? It would be much appreciated if you include as much detail as possible regarding this crash.
Thank you
