01-02-2014 09:20 AM
@abhishek.d wrote:
Sorry I didnt get exactly..you mean to say All the AO functions can be replaced with DAQmx write and all the AI can be replaced with DAQmx read..
Did you read through the KB article Dennis linked to in post 6 of this thread? Yes, we could go on for several pages explaining each of the concepts presented there. And, are surprisingly willing to do so. But a bit of reading up front on your part might help you more.
There is even this direct quote lifted from there.
"Although many of the programming techniques are similar, there are some slight differences that will be pointed out in this document. Please note that this article is intended to be a supplement to the other help documents available, not a substitution. After you understand what is described in this article, you should have a clear idea of the main differences to keep in mind when programming in NI-DAQmx.
Emphasis added
