ni max实时机IP地址更改不了
ni max实时机IP地址更改不了,改完之后重启还是原来的地址。
(1,044 Views)
@asdadsadas wrote:
The IP address of the ni max real-time machine cannot be changed, and it will still be the original address after restarting.
Check the following place if Reset IP Address is enabled.
1. NI MAX
2. BIOS
3. DIP Switch on the controller
https://tmesystems.net/
(1,004 Views)
Can you be more specific?I can't find it. Where is the exact location
Thank you
(994 Views)
Accepted by asdadsadas
I think I have remembered it wrongly. There is no Reset IP Address option in NI MAX.
For BIOS,
  1. During boot press the <Delete> key to enter BIOS setup
  2. Navigate to the LabVIEW RT section of the BIOS setup
  3. Highlight Reset IP Address, press the <Enter> key, and select No from the sub-menu
  4. Exit BIOS saving change
Reference: Cannot Connect to PXI Real-Time Target on a Network
For the hardware switch, there is a DIP switch on all NI PXI controllers. For example for PXIe-8840, see page 32 of PXIe-8840 User Manual
(984 Views)
