nimxs hanging at system startup
Hi everybody,
the last few days, I realized, that after start up of my computer, nimxs.exe slows down the whole system by creating about 99% of the processor load..... after several minutes, I choose to kill the process via windows task manager. After that it's not able to start Max anymore. If I start nimxs.exe manually everything is fine again.....
I'm running on a laptop without hardware connected (apart from a simulated PXI 6251) having installes 7.1.1 in parallel to 8.20 (PC,RT,FPGA) using the driver disk Aug 2006.
Any ideas?
Cheers
Oli
(3,965 Views)
Dear Oli
You could try to kill nimxs.exe, rename 'C:\Program Files\National Instruments\MAX\Data' folder (e.g. to 'Data2') and reboot ...
Best regards
Philipp Roessler
(3,941 Views)
Hi Phillip,
thanks for the tip. Everythings fine right now; the simulted device has disapeared, but that's no problem.....
I'm curious.... what was the reason for this behaviour?
Cheers
Oli
(3,928 Views)
Dear Oli
Can't tell for sure: might be you had leftovers of an earlier DAQmx installation on your machine, might be due to Shared Variables you used ...
Best regards
Philipp Roessler
(3,921 Views)
