nonlinear curve fitting for a lead acid battery PLZ HELP
@lil_zu wrote:
...is it ok i keep all my questions to this thread?
Only if it is somewhat related to the same problem. 🙂
Message 21 of 25
(1,234 Views)
so sorry to nag u again but i was wandering how i could read the x y data from spreadsheet and giv them to x and y inputs of the lev-mar function. once again im quite new to the labview area and sorry if its a noobish question 😄
Message 22 of 25
(1,223 Views)
ok i was able to read the data file which is a text file with delimeter tab. but how do i make this into 2 arrays so i can input X and Y seperately?
Message 23 of 25
(1,185 Views)
Easiest would be to delete the first line in the text file (the line containing the variable names).
Now take my last example, add a "read from spreadsheet file" and turn the existing array control into an indicator (right-click the terminal...change to indicator). Now it should look like that (the index array that you need is already in place. Check the online help if things don't make sense). :):
(If you want to keep the header line in the file, you need to skip the first line one way or another, complicating things.)
Message Edited by altenbach on 09-18-2007 10:54 PM
Message 24 of 25
(1,183 Views)
thx a lot..it worked out great. project continues 🙂 might need ya help soon 😄
Message 25 of 25
(1,136 Views)
