09-17-2007 11:08 AM
Only if it is somewhat related to the same problem. 🙂
@lil_zu wrote:
...is it ok i keep all my questions to this thread?
09-17-2007 02:52 PM
09-19-2007 12:23 AM
09-19-2007 12:51 AM - edited 09-19-2007 12:51 AM
Easiest would be to delete the first line in the text file (the line containing the variable names).
Now take my last example, add a "read from spreadsheet file" and turn the existing array control into an indicator (right-click the terminal...change to indicator). Now it should look like that (the index array that you need is already in place. Check the online help if things don't make sense). :):
(If you want to keep the header line in the file, you need to skip the first line one way or another, complicating things.)
Message Edited by altenbach on 09-18-2007 10:54 PM
09-20-2007 02:57 PM
