one of three conditions met, return true
I just see the OR (Express Boolean) where if one of the TWO conditions met, then return true to stop the labview.
Is there any Express Boolean provides if one of the THREE conditions met, return true?
(3,104 Views)
compound math, or as many conditions as you like
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(3,101 Views)
Sounds new to me, I try to find the compound math in the search, but coudn't found it. Can you help to explain a little bit/ post the vi?
(3,097 Views)
compound arithmetic in the numerics . right click and change mode to or.  it is growable like an array.
Paul Falkenstein
(3,095 Views)
Accepted by JohnS11
type in compound under quick drop.
Paul Falkenstein
(3,093 Views)
thanks bro!
(3,089 Views)
