12-29-2022 10:50 AM
I'll say that DVRs are generally not a good way to pass data between loops, especially if you have multiple loops trying to write to the same data. I would be more inclined to use a Queue or Notifier to pass your raw data to this loop and then you can process it as needed. The processed data could be sent on similarly usings Queue(s) and/or Notifier(s), depending on the number of loops and what those other loops are doing.
12-29-2022 11:25 AM - edited 12-29-2022 11:26 AM
The nice thing about DVRs is that they don't "pass data", but all point to the same data (semantics... 😄 ). I agree they are rarely needed, though. I think I only used them once where I had to share a huge 3D arrays, avoiding some data copies.
12-29-2022 12:35 PM
This might even be a good use case for a Channel Wire object. Depending on the degree of access desired by multiple loops.
However, a DVR to point at 24 clusters of data smells like a God Object from here! I would seriously rethink what subvis are doing to what data elements. And refactor while there is still time.
