order a vector from highest to lowest using recursion
Please don't insert camera photos!!!  😞 (you can can just select all on the diagram and paste into microsoft paint!)
  1. You need to initialize the shift register with an empty array
  2. use "built array" to append the new element. No need to wire [i]
Message 11 of 14
(918 Views)
a query that I put in case 1 but because it doesn't recognize the values and I get all zero
Message 12 of 14
(909 Views)
Please attach the VI. We cannot debug pictures.
You made several mistakes:
  1. there is no need for any local variable or array riffle function. What gave you that idea???
  2. The current "1" case should be case "0", right? Now think about what should be in it? (almost nothing!)
Message 13 of 14
(907 Views)
Thank you I already solved it
Message 14 of 14
(900 Views)
