peak detection for a noisy signal offline
Dear LabView experts...!
I am trying to find the peaks in my Signal offline . I like to find out the amplitude,location of the peaks and manipulate it. But the signal has noise and if i try to feed in this signal to a peak detector it gives false results as taking the small noise peaks . i like to get the large peaks (3 peaks in the given data ) .
Please help me out to detect these peaks.
When i used a peak detector.vi for a simulated noise less data its works fine. I am using LabVIEW 7.1.
Expecting your reply.
Message 1 of 11
(4,981 Views)
Then you use any digital filter you must provide some information about the timing (sample frequency/interval). Else it will not give the correct output result.
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 2 of 11
(4,967 Views)
Thank you for the reply. I tried to use the digital filters in the express vi but it gives out an error that the cut off frequency shouls be less than Fs/2 . The sampling freq for my signal was 7hz.
Please give the program in LabVIEW 7.1.
Message 3 of 11
(4,960 Views)
Sorry I can not save for Labview 7.1.
Here is a picture
Message 4 of 11
(4,954 Views)
I attached the sample interval (in my case 0.1429sec) . But i cant see any difference in the output.
Message 5 of 11
(4,948 Views)
Are you simply looking for the peaks? Does the time matter?
Tim
GHSP
Message 6 of 11
(4,939 Views)
Why such a slow sample frequency? A technique that I have used is to sample with a higher rate than needed and then average x samples together. As an example. Use 140 Hz as sample rate and then average every down every 20 sample to one , and present the result as 7 Hz samples.
Message Edited by Coq Rouge on 04-13-2010 02:12 PM
Message 7 of 11
(4,937 Views)
Accepted by bala1234
This will give you peak values without filtering. You could get the time with a little more coding.
Tim
GHSP
Message 8 of 11
(4,935 Views)
ya ..i need the time also too....! As with that peak amplitude i will calculate 10 % of the peak and where it occurs (time).So need the location of the peak.
Thank you
Bala
Message 9 of 11
(4,932 Views)
I set the threshold to 8 and the width to 300. Got the peak values of 16.5178, 18.8016 and 23.8797.
Tim
GHSP
Message 10 of 11
(4,928 Views)
