periodic counting
Hello!
This might be so easy to implement but not for me, at least not at the moment. I would like to create a CAD counter that I need to simulate for testing a subsystem I created, for demonstration purpose. The need is to be able to count from -360 to 360 with a resolution of 0.1 ( preferable if it can be adjusted as the need comes) periodically. i.e Once one full cycle is counted [-360,3609], then the count is supposed to start over.
Has anyone implemented this before? I very much appreciate the help I get.
As always thanks for all the helpful guys up here!
Message 1 of 22
(6,301 Views)
Hi Henok,
sounds like you need a comparison function. Quotient&Remainder might help too...
Counting up to a limit and starting over again is a common task. Some pseudo code to get the idea:
ctr := ctr + 1
IF ctr >= upper_limit THEN ctr := lower_limit
Message 2 of 22
(6,293 Views)
Could you be more elaborate please? Like an example?
Message 3 of 22
(6,282 Views)
2011 compatible vi please
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 4 of 22
(6,278 Views)
Hi Ranjeet,
Here is the 2011 version of what I tried to do 🙂
Message 5 of 22
(6,275 Views)
Hi Henok,
try this:
It's just a simple math: use your loop count to calculate your scaled value...
Message 6 of 22
(6,261 Views)
Hi Henok,
                                 I am attaching one VI. Enter 'resolution' &  'Delay between two count in ms' & run the program.
Try resolution as 1 & Delay between two  count in ms as 100 & see.
Hope this is what you are looking for. Let me know if you need any explanation.
--Ranjeet
Message 7 of 22
(6,243 Views)
Thanks Ranjeet!
Its very impressive! I just could not know why it doesnt work for different resolution ( I tried 0.1 as it was my target). I tried to tweak the values and see if it works, but once it starts 360 with the current count, it kept counting up instead of starting over from -360. Any idea why?
Message 8 of 22
(6,234 Views)
Please try this & let me know.
Kudos are always welcome.
--Ranjeet
Message 9 of 22
(6,230 Views)
Hi Henok,
the problem arises from using the "equal?" comparison on floating pouint numbers.
Ranjeet forgot the inaccuracy of such numbers as was explained a lot of times before in the forum...
Conclusion: NEVER compare floating point numbers for equality!!!
That's the reason why I was using integers for the "counting" part in my example followed by a simple scaling to your desired range...
Message 10 of 22
(6,229 Views)
